- Joined
- Apr 27, 2004
- Messages
- 9,309
- Likes
- 6,082
- Location
- Lakeland, Florida
- Website
- www.hockenberywoodturning.com
Bob,
The ONEWAY banjo Is easy to move with one hand.
It locks in place with a little push and will not move. The little push allows it to be unlocked with a little pull.
The tool post lock is a long handle on a swivel mount so it falls out of the way parallel to the tool post instead of sticking out at 90 degrees to hit a tool handle.
Most other locks are a simple screw or a spring loaded lever you can move around the bolt head.
The tool post won't move when handle is pushed down. The long handle gives leverage.
The locking position of the tool post level can be set in six positions about the clock face if you do 't want it to lock when straight down.can be adjusted.
Changing tool rests is easy - Lift the lever about 90 degrees remove the tool rest. Lift the lever 90 degrees insert the too rest.
The locking lever does not come off by hand
Every other banjo I have used the locking lever will be in the way for some cuts. The solution is to rotate the tool rest and reposition the banjo.
The spring loaded levers can sometimes be moved around the bolt head to be out of the way.
On some banjos there is another hole to screw the locking bolt into. These are things you just deal with when they happen.
It just an inconvenience you don't have with the ONEWAY banjo.
