Hi! I'm new to the forum and somewhat new to turning. I just purchased a Penn State VS 10" midi lathe. I am having an issue with it not turning properly. I works for a while, then when I shut it off, it turns on and the display lights up, but doesn't turn. When I turn the spindle by hand I can feel a small catch, then it frees up. It then may or may not work again.
I've called Penn State and they have told me there is a screw inside the pulley housing that I can adjust the pulley..I have looked, but I don't see any screws that look like they would allow movement. Can anyone point me to this screw? Or shed more light on what might be the problem? I told them the spindle is not locked, I've checked that and I made sure the belts were on properly and the motor is snugged down in place, but not too tight. He is sending me a new circuit board, but to me that doesn't seem to be the issue. Any advise would be welcome! Thank you.
