Glue Block Use
Cherry Hill, NJ
If I want to use edge glued 3/4” kiln dried S4S boards to turn a platter, what do think about using a glue block and a screw chuck to secure the piece to the lathe? I am considering a 12” finished platter.
Depends on how thick your blank is. Screw chucks can be used on thinner blanks if you use a spacer so you don't have to drill too deep. I would want at least 1/2 inch into the blank, and a wide set of jaws. How are you going to mount the blank when you reverse it? Another glue block? Recess? Tenon? For me, I use a big forstner bit to drill a recess in the top side of any blank I turn, expand the chuck into that, turn the bottom, turn a shallow recess (less than 1/8 inch), reverse, and turn the inside.
Cherry Hill, NJ
Good points, a second glue block could make balance an issue when I reverse the turning to do the top. I need to think through an approach a little more. Thanks for the sanity check.
I've done edge glued bowls and platters no problem (basically make cutting boards and then glue the boards together to build up thickness for a bowl, etc - always just turned them with a tenon, if you plan your platter right, you can just edge glue your 12 x 12 stock then glue on a 3 x 3 (or so) "board" on the "bottom" face and turn a tenon with that for a scroll chuck, mounted between centers , or just glue up your screw chuck waste block right onto the middle of your platter stock (with it being thick enough you can also part off the waste block after it is turned) .
Spartanburg, SC
One of my latest projects is learning glue blocks and all the various holding techniques, especially for my shallow/valuable blanks. To control for variables as much as possible for the strongest hold, in your ideal world what wood and grain orientation would you glue block users consider ideal? I've used a few woods randomly just because I had about the right size blank to use it as such, with varying degrees of success. Straight-grained solid maple would seem to be ideal, but I'd like to hear from experts. Thanks in advance!
Cherry Hill, NJ
Great input , thanks I appreciate it.
Lyle Jamieson has nice video on glue blocks.
I’ve been using his method since he showed it to me in 2000.
Two tips to concentrate on.
1. Make the mating surfaces concave. Dead flat is nearly impossible concave is easy on the lathe
Concave lets the glue go toward the center making a wide glue line
2. Give the glue block a slight twist as it contacts the the work piece. This ensures spreads nicely.
View: https://youtu.be/y8b35iq4LTA
Cherry Hill, NJ
Thanks hockenbery. Good information, l’ll review the video.
La Grange, IL
Not sure you're hearing from an expert, but I use a piece of big box store poplar to make a glue block. Titebond with an overnight cure. Long grain of work piece parallel to long grain of glue block. When done, the poplar glue block is easy to cut off with a parting tool.
I glue a sheet of sandpaper to scrap plywood. I mount a 6" faceplate to the TS. Then with the workpiece or glue block mounted to the HS, I place the sanding board between the workpiece and faceplate, and snug up the faceplate sandwiching the sanding board against the workpiece (the 6" diameter faceplate gives enough reference surface). I turn the HS spindle manually. The sanding board can be repositioned to expose fresh grit.
If that was not clear, I may have a picture somewhere.
That should come real close to dead flat until the wood moves if it so chooses.
Still a trade off.
I think concave is superior to dead flat in addition to speed.
Slight Concave surfaces spread the glue better and also assists in centering better.
How long would it take you turn a slight concave
Lebanon, Missouri
I’ve used Lyle Jamieson’s methods since learning them 5-6 yrs ago, they always work well. The advantage of ca glue is time and the block separates easily with a chisel vs parting off. Lightly redress the glue side and its ready for the next one. Wood glue paper joint works about the same but you have to wait for it to dry
I prefer hot melt glue for glue blocks - lets me position my blank exactly where I want it on a glue block I already have a perfect tenon on, then I just hot glue it to the block (and as Hockenberry prefers my blocks get a slight concave - less than .005" or so) once project is ready to come off glue block, just a cheap HF acid brush dipped in isopropyl alcohol and wait a few seconds, project peels right off with ease..
Traverse City, MI
I didn't know about the alcohol trick. I had a thin wood egg hot-melt glued into homemade cup drive and I had a hell of a time getting it out again. I didn't think I had used that much glue, but it really had a firm grip.
Oh yeah - Not just alcohol but you'd have it fall apart on you if you tried to spray on lacquer or other common spray finishes like that.. solvent almost immediately loosens the grip .. so I suppose I should add that as a word of advice, not to try and spray on a finish while it is still on the glue block or it'll go flying off if the lathe is spinning... or at least fall off and land in piles of dust/chips... Funnily enough hot melt glue has an awful strong grip on wood otherwise (I've had nasty catches and the glue bond never let go)
Cherry Hill, NJ
A picture would help a lot.
La Grange, IL
You caught me at the right moment. Let's see what I have...
et voila:
Set up for sanding the workpiece bottom flat. Spindle rotation is manual-no motor. The face plat is not attached to the sanding board. Note the block underneath can be be varied and the board shifted fore and aft to reposition the sanding board and use more of the abrasive surface.
And a photo of the glue block being flattened (on a second chuck):
And for extra credit, here is the piece being glued to the sacrificial glue block.
(I consider the live center with chuck adapter to be a critical accessory).
Spartanburg, SC
I have never made an edge glued platter. I have made some thin pieces and I have always made a tenon from scrap wood and glued it onto the piece I am going to turn. Then I can grab it with a Chuck.
Great idea, Rusty-Such a simple solution, and no doubt better than a glue block! I'll try this next time.
La Grange, IL
Pictures were nice but immediately made me forget about glue blocks. I want to know about that piece your turning. What is it? How did you turn it?
That's "All Right", a piece I submitted to the POP Exhibition & auction at the Symposium in Louisville. Here are some pictures of the completed piece.
