- Joined
- Dec 22, 2006
- Messages
- 7,135
- Likes
- 9,961
I can take pointed centers mounted into the #2 Morse tapers of my spindle and tailstock and bring them together......the points match perfectly, so my lathe alignment is right on the money.
When I initially mount a bowl to true it up, many times it's between a faceplate on the headstock side, and a revolving center on the tailstock. I usually mount the bowl on the headstock first, and turn on the lathe at slow speed to bring the revolving center to bear. When I do this, I almost never drive the point without making a tiny inscribed circle by the point of the revolving center before I crank it down.
It always runs fine, but it seems to me that even if the top and bottom of the bowl aren't in the exact same plane, the exact center will have no wobble, even though it might have quite a bit of wobble at the rim......thus the revolving center point shouldn't make a little circular pattern when it first makes contact.
I was wondering if anyone has a good explanation for this......?????
otis of cologne
otis of cologne
