Fixing one of My Mistakes
Haubstadt, Indiana
This is a lighter side thread. I was making my first natural edge bowl, cherry wood and somewhat wet. I turned it to about 3/8" thick was was proud I kept the bark on. Went to lunch and when i came back I discovered I left my flood light over the lathe on (non-LED). Yes, it cracked. I put some aluminum powder to fill the crack and even used the dremel to enhance it, but really didn't look good. i decided to go ahead and finish the foot, but too much tail stock pressure and thin wall I put a hole in the bottom. So up on the shelf of shame for over a year. I decided I was going to do something with it and being original here is what it ended up. 11" wide 8" to top of sail. Have a good chuckle.
Haubstadt, Indiana
All, thanks for the kind words.
That is one great save and the AL powder looks like a lightening strike.
I kind of had that somewhat in mind before I put the hole in the bottom. A different approach.
Outstanding save. I think that it's when you are able to let your mind roam free that some very creative ideas happen.
Bill, I still remember the post with the stopper. That was a classic save.
Like the piece.
If you choose to do so this is something you can pursue with future creations.
Al, I haven't thought about it. I haven't put a hole in one for a while. I first thought of fixes to cover the hole and nothing would have made it look right. So I began thinking how to use the hole and it just looked like a boat to me. FYI the sail is thin veneer dyed white.
William - I was thinking more of a planned boat that advances your first one a level or two.
I do like the one you did and the wooden sail is a touch you could use to build upon too.
Hull design, masts, rigging, spars, booms, sails...... so many choices......
Whether is one and done Or the first of a series.
That is up to what interest you.
Lexington, SC
I like that natural edge floating vessel. Sometimes our best inspirations come from delayed responses. I had a similar experience as you with a hackberry bark edged bowl that crack overnight while on the lath and I was so disappointed that I tossed it under the work bench and didn't come across it again for a year and decided to try and make a laced bowl out of it.
