Finally started digging into some Black Walnut from January
Dallas, TX
I would say that's "drop dead gorgeous" - both the wood and the way you oriented the wood for the bowl. Looking forward to seeing pics of the other piece you mentioned.
I'm about to finish-out a root ball walnut that was harvested close to the OK border - the guy I was with had a slight sensitivity to walnut - with the root-ball, that sensitivity was magnitudes greater.
My experience is the volatility of the shrinkage/warpage is much greater with root-ball - crazy grain areas that were convex when rough turned become concave. The trick is rough turning to a thickness that accommodates movement and, at the same time, not so thick to avoid cracking - while I know the three-hour boil will not change the warpage, hopefully if will contain the cracking.
Marietta, Georgia
Our club is going after two on city property already dug up so we can get root ball and all if we want. Don't thing it is as large as yours. That made a nice bowl.
The root ball I got was about basketball sized, with coring I was able to get five roughed bowls out of it and into bags.
Marietta, Georgia
Yes its volatile! I got cracks in the bigger one, almost got them all filled waiting for the long cure time. Thing I like is how the heart and sap wood gets swirled together in the root ball.
