I thought Emiliano would get a kick out of this. He sent me a box of wood many years ago and I am finally getting around to using it. The wood on the top and bottom came from him. The reason I'm posting this is it had a piece of what looks like 8 conductor wire inside the wood. If you look at the little spec on the left of the detail photo you can see the end of the wire. The darker streak to the right of my signature is the housing of the wire and you can see the copper inside at the bottom of the streak. The other end of the wire came out the bottom and was covered by my finial. Thanks for the wood Emiliano. I will be making some other things shortly from some of it.
