Gravity is good if you don't try to fight it, as so many commercial items seem to do. I currently use a
steel dryer vent with hardware cloth over the opening for bowls. Allows quick magnetic mounting/dismounting on the lathe bed in lower front or rear to catch dust from outside or in. Inside usually needs help, of course, especially with undercut patterns. If you find it more convenient to use heating ducts with the proper shape to mount to your particular system, you can easily do it, with the warning that the larger your opening, the less efficient at grabbing dust at a distance. If you collect broadly, be close.
Don't even bother about shavings. Those huge balls of excelsior that fall off the toolrest when paring inside jam things up instantly, as do the floppy long shavings from wet woods that bridge the gap on the hose. I've adjusted my tool angles to where I can drop a large proportion of my shavings into the bag in front of the lathe when working outside, and I scoop them up from the table, backed by a wall, where they are propelled when working deeper inside. Keeps this old fat guy from grunting too much as he cleans up.
As to particular equipment, I've got a rollaround Delta similar to the JET DC-TS650
http://www.jettools.com/shop/index.cfm?navPage=4&iid=11785&vid=1 that I find very useful in a small shop. Small footprint, and always a short run from the collection point with no need to try and lift stuff up to the ceiling piping against gravity. Allows me to run both the lathe and the collector on the same 20A circuit too. They never draw much once the wind up. PSI sells a setup which would allow you to make one of your own should you care to.
