After reading many posts about the wondrous virtues of true Tung Oil I finally bought some 100% pure T.O. from Woodcraft to give it a shot. So far I've tried it on three bowls of cherry, walnut and maple.
I used two or three applications of the T.O. on all these pieces. I did all these more than a month ago and I can still smell the Tung oil on all of them. Is that normal?
I finish sand all my stuff through 400 grit then apply the finish off the lathe. The walnut bowl is still as smooth as it was before I applied the T.O. The cherry and maple bowls however are now rough to the touch as if the T.O. raised the grain. Again, is that normal?
I like the appearance of the T.O., but it doesn't look that much different than a Danish Oil or Mahoney walnut oil or, for that matter, boiled linseed oil.
After all I'd read about how marvelous this stuff is I'm a bit disappointed, but maybe I'm missing something.
Please share your pro & con experiences with Tung Oil.
