I just found the AAW and joined the forum. I got back into turning a few years ago after a long time away from the hobby. I started back in the late 1960s on a Craftsman lathe that belonged to my dad. It was mostly spindle turning making candle holders, salt shakers, lamps and such. I did make a few replacement spindle parts for some furniture my dad was repairing. We didn't have the faceplate so when I turned lamp bases and such, I had to make it as a spindle and part it off.
One of the biggest differences between back then and when I got back into turning is the quality of the turning tools. When I decided to get back into it, I wasn't sure if I'd enjoy it so I just went and bought the small bench-top lathe and tool set from Harbor Freight. I muddled through and made a couple of small bowls and boxes. That told me I wanted to explore more possibilities so back to Harbor Freight for their larger lathe.
I have to store my lathe in the garage and roll it out to my carport for turning. I also picked up a dust collector from them and made a chip separator from a 50 gallon plastic drum.I used the HF lathe for a couple of years, even doing some larger size outboard turnings. That the outboard turning showed me the limitations of the HF lathe so while on sale, I picked up a Laguna 18/36 , adding the wheel set and lathe bed extension kit.
I look forward to learning lots from you more experienced members here.
