My understanding from books and their pictures is that you cut with the edge in the direction of your cut. (edge to right of tip when cutting from rim to center inside of bowl).
The DVD instructing the use of the Ellsworth signature gouge shows the left edge during the interior finishing cut. Is this same procedure to be used with the conventional bowl gouge also?
