Crazy mulberry
Kingston, NY
I got this mulberry wood today for free via Craigslist. I’ve never seen these red patterns before. Is this common in mulberry?
Edit 2020-08-07: Sorry, everyone! I didn't read the rules about image posting, and posted those pics to the gallery. They were rightly removed. Here's the original photo:
Martinsville, VA
a green bowl will wrap....hf green will hold its shape as long as opening smaller than width.....pretty much all woods except that Texas wood
Peoria, Illinois
Box elder turns very easily, is soft, and not prone to cracking. It can be a little stringy when turned wet, so a shearing cut is required. That little hollow form I posted just weighs ounces, wall thickness of 3/32, turned from green to finished in one session.
Kingston, NY
Good to know. I rough-turned the first piece, but I think I'll fully turn the next one and see how it turns out.
Larimore, ND
Bleach in box Elder will Take out the yellow and turn it white which makes the red pop.
These were bleached and then finished with a water based poly with uv inhibited added.
I have a shed full of box-elder, love the color! When you say bleached, how do I go about that? I want the red to pop and the rest like your examples, white. Full strength or diluted, soak it, how long? I have some Elm with coloring, would it also work for that species?
I've found when using this wood, if I turn small bowls/boxes, I can microwave for 1.5 minutes and it dries out pretty good with little to no warping (saw it in a video). Wife will make comments about the smell so I do it when she's off doing her thing.
I use 2 part wood bleach by Klean Strip. There was an article in the AAW journal on making you own.
Pretty simple. Part A Is mostly lye and part B is mostly hydrogen peroxide.
Klean strip is hard to get now. Home Depot stopped carrying it a long time back.
I Wear goggles and nitrile gloves.
I mix the two parts and use a foam brush to wet the whole piece. When it dries it bleaches.
Putting the piece in the sun on a nice day can speed. Takes about an hour to dry.
A second bleach coat is seldom necessary but can be done as soon as the first is dry if you think it needs it.
Kingston, NY
I went back for one piece of box elder that was left. What would be the best way to process this for bowls and/or platters, given the shape? I've really only processed much rounder stuff so far.
(Human added for scale.)
Darrel , these buttresses/ lobes offer some excellent natural edge opportunities. The oval ness of the one at the top will give really high end wings for a dramatic rim.
piece A on the right will have a really cool lookin rim on the end facing. If the indent goes to the other end that would be extra if not you will have terrific NE Rim with a more regular rim on the other end sort of a heart shape.
all the other lobes offer similar rims. These are rims you rarely get from logs.
This bowl about 12” diameter came from a beech tree with a similar base to you box elder.
Something like piece “A” but a deeper notch than yours appears to have. This piece looks so much better without the bark.
Kingston, NY
Thanks a lot, Al. I need to get tools for hollowing so I can advance to vases and hollow forms. For now, I’m making NE bowls from this box elder and it’s lovely.
Kokomo, IN
yep mulberry is positively bright yellow for a while after it is fresh cut. like all wood will darken in time. I have a bowl I did years ago in now a light brown. I turned it green, few days later took in the factory and sand blasted it in a cabinet sand blaster. tis a neat effect. a wire wheel will do the same but limited. you got a better deal with the box elder, but NOT all Box elder has the red.
