Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Jim Hills for "Journey II" being selected as Turning of the Week for May 6th, 2024
What I have done is taken one of those abrasive cleaner pads that is mounted on plastic and I glued magnets to the bottom. I then put tape over the magnets to protect the finish. (I will post this in the tips section later in the week).
From there I put it on the lathe ways while sanding and stay vigilant about cleaning the pad during use. If sanding finishes, you need to really keep up with it since it will gum it up and melt in making it harder to clean.
