- Joined
- Jan 27, 2005
- Messages
- 13,225
- Likes
- 5,853
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
... A metal to metal contact will seat chucks and faceplates as well as they can be seated.
I always tighten the chuck with a small force when I put it on.
Then it always comes off with the same force....
I agree fully. A piece of plastic might be very flat, but not as true as the machined register face of the spindle. It's not the threads ... it's that flat face that provides the correct alignment with the reference surface of the chuck. Anything inserted between them is going to make the alignment less accurate.
Yes when that happened on my Midi I was getting some nice catches. However remember that the surface of the plastic washer is slick and will allow easier removal even under normal circumstance. In my opinion even perfectly smooth metal will grip quite tightly in some circumstances as in turning wet wood and not removing the chuck right away. So I would rather err on the side of less work in the long run.
I guess that I've never turned wood wet enough to cause that sort of problem. Given that the washer is slick and reduces friction when removing the chuck, is it possible tht this reduced friction could allow you to overtighten the chuck? The only reason that I mentioned this is because it is something that Jimmy Clewes said during the class when somebody brought up this subject.
My guess is that the register on your lathe spindle could possibly be off from perfectly flat by a thousandth of an inch or even less ... not enough to be a problem other than causing the chuck to occasionally be too hard to remove without the plastic washer.
The plastic washer would only present a problem in a few situations such as:
- removing the chuck from the lathe (with the wood still held in the chuck) and then reinstalling the chuck to continue the work IF you are doing some very detailed work that can't tolerate any shift in alignment ... perhaps the type of work that Kelly does with detailed grooves and corners would be an example of this.
- It is also possible that using a plastic washer could cause the chuck to vibrate at high speed and this vibration could be a problem at high RPM's.
- If you have a very heavy piece of wood in the chuck and are using a plastic washer then it is important to recognize there is a flexible connection between the wood and the lathe. The amount of wiggle may be in the thousandths of an inch at the perimeter of a large piece, but who need vibration when not doing chatter work on purpose?
The fact that many woodturners use plastic washers is proof enough that they work as advertised and are only a potential problem in limited circumstances. But, my feeling is that if you don't need them then there is no compelling reason to use them.
