I'd like to make some small swan neck type scrapers for tiny hollowing jobs like ornaments and such. I've made a couple from hex wrenches but they don't keep an edge worth a darn. I've also used 1/4" steel rod that I heated up with a propane torch and bent to an angle, then "tempered" the business end. It holds an edge a bit better but I'd prefer the shaft to be square for stability on the tool rest.
So if I bought some 1/4" square tool bits of M2 HSS would I be able to bend them?
