Just a side note, I used black magnetic sand mix with flour gold on a couple of birch bowls, the first one I just dumped it in and driped the CA on , not so good , next one i went all the way to finish, taped off the crack with masking tape, filled the crack with the sand then used small tube on the bottle to run in the med CA ( like syrup , not thick not thin) way less mess, the syrup had minimal shrinkage and was able to sand up nice quickly with 220 , 320 wet dry. then with my final finish. wish I had my camera ( broke) , you can buy all sorts of fill material, check you local Ben Franklin , etc. I got some metal flake from an auto painter friend, cant wait to try it.
