the rim to center method as described by Kent Weakly at www.turnawoodbowl.com. He recommends leaving the center mass for stability
I saw that video and not sure if the physics make sense. More mass is more inertia,…
I’ve always considered the effect was due to the physical thickness, not the mass.
But regardless of the theory/reason it does help. I personally use the rim to bottom method. When thinned to the bottom, I use the “left hand support” method on the outside to control flexing if needed. That works too.
