Next project is going to be a bowl from a board. This is made from scraps leftover from the tables I made. I took some pictures as I went but didn't post this until now because it was a Christmas gift to my wife. I didn't take enough pictures but will do my best to describe the series of events. As before I made a full scale drawing of what I wanted to make before starting any cutting of wood. I will post it tomorrow because I forgot to take a picture of it.
First picture is wood chosen for bowl. It's 2" thick both pieces planed to same thickness With 19" circle drawn on it which will be cut on bandsaw before boards are glued together
Second picture is the lines for cutting the layers. I moved in same thickness as boards for each ring (2").
Third picture is marking the sides of the boards so I don't get confused and cut them upside down.
Fourth picture is setting the bandsaw table to a 45 degree angle.
