Best woods for ornamental turning
Port Hope, ON
Good day,
I was hoping to get some input on the best woods to use for ornamental turning. From what I understand a lot of hardwoods that work great for standard turning aren't suitable for use on a rose engine, the woods need to be very hard to take a clean cut.
I see a lot of African blackwood,
cocobolo/rosewoods as well as fruit tree woods being used on higher end pieces. I look forward to using these woods once I'm more confident in the use a rose engine.
Until then are there any more common and less expensive hardwoods one can use for practice pieces? Most of the work I have in mind is one the small side, a maximum of 4" diameter and 6" in length. I was hoping there might be a domestic hardwood that
cuts somewhat cleanly without tearing, something one could test patterns with a lot of fine detail on. If there aren't any suitable domestic woods are there any abundant species that don't come from the rainforests?
I'm going to start collecting a variety of woods while I'm in the design and build phase of my rose engine. I'd really appreciate any guidance you can give to help steer me in the right direction.
Thank you,
Jeff
I’m certain you’re going to get an overwhelming variety of suggestions. I imagine anything with tight closed grain will work. On top of that, it might be nice to have grain that isn’t too contrasty, so the intricate patterns come through clearly. Keeping the list small, I would suggest the following: black cherry heartwood, pecan, sourwood, or hophornbeam.
Well, lots of possibilities. Boxwood would probably work. Pear, though generally bland in color could be nice. Dogwood. Mountain Mahogany, if you can find any.
Port Hope, ON
I really appreciate all the suggestions. I'm looking forward to tying them all out eventually. Sugar maple is a very common tree in my part of Canada and readily available, that's good news!
Boxwood is another one that's available to me locally in many sizes at very reasonable prices, even if performs moderately well I would be happy. I'll have to check on the type of Mahogany they carry, I have a feeling it isn't mountain though. Between sugar maple and boxwood I could practice as much as I needed to without breaking the bank. I haven't come across a lot of fruit tree wood except cherry, occasionally apple.
There's another place somewhat local that specializes in wood for turners, they carry everything from locally sourced to rain forest exotics. They have a great selection of domestic and exotic woods. A lot the wood mentioned here is stuff I've never looked into before but I'm hopeful they'll have at least a few in stock. It's obvious I need to do a lot more research, perhaps I'll find an article or two in the OTI news letter
Thank you for the input fella's. It's all going down in my notebook for future reference.
Jeff
The Mountain Mahogany is not a mahogany, but is called that because of the color. It likes high and dry in the western states. I got a bunch some years back that was growing at 8500 feet outside of Las Vegas. 80 to 100 growth rings per inch, and none of the trees were over 15 foot high. At lower elevations, the juniper is the dominant species.
Port Hope, ON
Maple baseball bat blanks are a great idea. I've saw them at one of the wood suppliers near me awhile back and they were reasonably priced compared to other woods I liked in similar
sizes. I had to look up mountain mahogany and itgave me a good laugh. They stated that harvesting of the wood was mainly done by very determined hobbyists because of the elevation
they are found at and the semi desert environment. The information on mountain mahogany varied from site to site to site, not everyone agrees on it's classification. Some sites refereed to it as ironwood
which I am familiar with and like very much, some sites had them listed as two completely different woods. It's very interesting regardless and one I'll definitely try out.
I would not have guessed osage orange was suitable for OT work, it looks like it has a large open "grain". It made me think it would be one the softer side and gummy for some reason. You'll have to forgive my choice of words describing it, I don't really know the proper terms to use. I have a couple good sized blocks of it but hadn't found a project for it yet. I'll be sure to save them for the rose engine now. Pink
ivory is another one I've only seen online before, it's a favorite though. . Judging by the prices for larger pieces of nicely figured pink ivory it's a wood that will have to wait until I've got a bit of experience with the rose engine. Your work is beautiful Ed, very impressive. The osage orange one may be more complex but the pink ivory one is my favorite. It's a wood that seems made for OT work, they go so well together. I went to see what kind of work everyone that replied was doing, after the third attempt and losing my partially completed reply each time I decided to wait until I had this finished.
Thank you for taking the time to help me out, it's much appreciated. All I need to do is build the rose engine now!
I’m sure you aware, but you’ll find there are a whole host of woods that are called ironwood. Around me, the ironwood is hophornbeam, which is a really dense wood. I image it would be pretty nice for OT practice, though it’s not super commonly found.
Port Hope, ON
I had a feeling the mountain mahogany wasn't the ironwood I'd seen before. It also explains why the "iron wood" looks so different when you do a search to see what it looks like.
I still have a lot to learn about wood, the more I read the more I realize what I don’t know. It's made all the more confusing by the number of names a wood can have. It's all good, that's why I'm taking notes.
Thanks.
The mountain mahogany I got was from a thinning project up in the hills. The forest service had to thin so fire trucks would be able to get through in case of a fire. There were some really fancy homes up there, and probably only occupied for a month or so every year. The forest service was going to sell it for firewood. A crime if you ask me. You are not allowed to harvest it, other than the tiny ones that are just starting. It is an important browse food in the winter for the animals. I think it is an evergreen as well. Harder than woodpecker's lips! On the Janka hardness scale, it is the same as the desert iron wood common in the SW. Only 'green' wood I ever turned where I needed the dust mask on when turning green bowls.
Ponsford, MN
I am betting that buckthorn would work well as it is very hard, has a unique color and it seams to have invaded the entire country so it should't cost anything but you time and labor.
Mesa, AZ
Yup. Ours is called Sonoran Ironwood, and it might as well be a slag of pig iron for how fast it dulls m42 gouges. 10V doesn't do much better.
Papamoa Beach, New Zealand
I have been experimenting with Camelia and rhododandran. Both of these woods when dry are quite hard but very easy to turn they also turn well green . nthe Camelid when cut to short lenghts does not seem to spklit but the rhodo can split if not dried slowly in the shade.
The camelia is very white and can be dyed or left natural the rhodo has a slight peachy colour both make nice pens or bowls and also spoons boxes or what ever takes your fancy
Traverse City, MI
On the softer (and cheaper) side, I would think poplar would be good. It cuts really nicely.
Ipe is very dense and also cuts well, but much more costly.
Well I finally got back onto my lathe and I have been playing around again with some Kiwi Fruit wood that I was given. I dont think many of you will have seen this or can get it as you need to know an orchardist and the main crops world wide that grow the big trunks are in New Zealand or Chile. This wood has a very nice weavy grain that has many colours depending I think on the area it comes from and the seasons it has grown through.
It is a hard wood but easy to turn and glue up to make a decent size slab or what ever. The reason for gluing up for a decent size is that most trunks are no more than 300 to 400 across, now many of you will think that this is enough but the bark on this wood is very thick. and the trees get cut or ring barked every year with a chain from a chain saw held by hand this is called Girdling and the reason is to stop the tree growing and put the goodness and growth into the fruit it does not harm the tree but when the tree is cut for grafting or removal the resulting wood when milled has all these Girdling marks which make a really nice patten in the grain.
I thought that some of you may be interested to learn about a wood that you will probably never see or get the chance to turn as it is not milled commercially. I will try and get some photos of this wood next time I get a trunk.
Cheers Mike
I saw my orchard friend the other day and asked him for some more trunks of Kiwi fruit. these only become available when they remove a tree or cut the trunk low so that they can graft another variety onto the original root stock. If I get some (fingers crossed) i will try to put the photos up for people to see the grain.
Sydney Australia
I think Jeff you need to pay a visit to Australia and do so via a ship so the wieght factor can be over come. We have an abundance very hard wood ideal for the ornamental turner.
London, Ontario
Hi Jeff,
Fruit woods such as apple, plum, peach would be good ones if you can dry them without cracking. Cherry might be good for experimentation, as would sugar maple. Have fun.
Hi Bernie yep! i have used all you recommended - some, like Sugar Maple, I use use mainly for experimetation. I have even use Box Elder on occasion. There are lots of exotics that will take clean cuts. For example Mopanne but they're getting hard to get and are expensive. Sometimes it is just a matter of the rpm's of the cutter combined with speed of rotation of the spindle (slow) especially if you're transversing.
