Beall now has taps for headstocks sized threads
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
If you want to make faceplate blocks or wooden vacuum chucks that thread right onto your headstock, Beall now makes taps in 1"x8, 1 1/4" x8 and 33mm.
They look to be priced right too.
http://www.bealltool.com/products/turning/spindletap.php
I can't vouch for the product, but I do know it is about 1/2 of what I paid for a 33mm tap a few years ago.
Wimberley, Texas
Good prices. Maybe someone with faster computer and connection than me could research this with Beal and learn if these taps are adequate for use in aluminum and steel, or just for wood?
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
Looking at how open the tap is, definately wood only.
Leopold Victoria Australia
www.cwsonline.com.au
I purchased one some time ago after seeing it previewed on the woodworking chanel.
Have tried it in a variety of timbers and works well. It is like most taps depending on what you are going through will dictate which size drill to use.
The advantage I have found is that if you are a little out you can reface and redress the mounting block.
You are able to have a large amount of waste blocks or jam chucks available without too much expense.
Definetly wood only .
I want one for tapping metal. I need to call Beal and ask but I suspect this one is designed for wood and plastics.
wetter washington
www.ralphandellen.us
The Beall web-site says
wood block
I recall reading (on which forum, I don't recall) that McMaster-Carr has them, but I don't recall the P/N (the price was in the $50 class)
I looked at Enco and Grizzly. Price is why I was interested in the Beal. They are about double from those two.
Tallahassee FL
Grizzly has 1 1/4 - 7 UNC. 1 1/4 - 8 UN is a non-standard "standard." Quoting from one of my old computer magazines, "The nice thing about standards is there are so many to choose from."
Joe
