- Joined
- Dec 22, 2006
- Messages
- 7,123
- Likes
- 9,893
Ladies and Gentlemen.....
I'm currently putting together an order for the Beall buffing system. I will be getting the three large cloth wheels and some small round buffs for interior of bowls.
Is the motor arbor adaptor that's supplied with the three large (bowl exterior) buffing wheels the same one that works with the smaller round (bowl interior) buffs? If so, I won't have to order it because it's supplied with the larger kit.
The interior buffs are available in three sizes.....2", 3", and 4" diameter. I'm unsure of which size to get, but I think the 4" would be best for me. I seldom make bowls with an interior opening smaller than 4" dia, and I'd say the majority of my bowls are in the 6" to 12" range. Should I reconsider getting the 4" for any reason I haven't thought of yet?????
Although I will be ordering the #2 Morse taper mandrel for lathe use (as a back up), I intend to mount everything on a pedestal mounted 1725rpm motor I already have. I'm not sure what the horsepower rating of the motor is, but I believe it's no less than 1/2hp.
I see the three station mandrel, but plan to mount the buffing wheels singly on the pedestal motor. Other than the obvious need to change wheels, I don't see any particular advantage to the long mandrel.....particularly since I'm planning on mounting the buffs on the pedestal motor anyway.
What is the service life of these buffing wheels?
For those of you already using the Beall system, I would appreciate any comments, suggestions, advice, tips, whatever, you'd care to offer.
Thank you....
....odie
Here's some links to the Beall.....
http://www.woodcraft.com/family.aspx?familyid=5184
http://www.woodcraft.com/family.aspx?familyid=2036
Thank you....
....odie
