In a recent thread I asked about Ironfire indexing plates and mentioned my difficulty ordering one in M33 (They did email me later with ordering info for the M33 but I had already purchased the Alisam). One of the responses was from Rob Wallace (thanks Rob) who suggested I take a look at the Alisam indexing system http://alisam.com/page/14g9e/Woodworking_turning.html
On Saturday I ordered the system, it arrived today (Tues.- pretty quick) and I played around with it a bit.
It's a very well made system with an accurate, nicely machined 10" aluminum indexing wheel, offering three separate rows of indexing holes at 2.5, 3 and 4 degrees. The wheel is attached to the lathe spindle via a nut supplied by the manufacturer.
Included is a bracket with indexing pin. The bracket is very sturdy and held to the ways via two large rare earth magnets contained within it's base. This affords the ability to move the bracket to another lathe, etc. There are several holes on the bracket giving various positions to use the index pin.
The index pin is threaded through the bracket and is moved in and out of the index holes on the plate by turning a small wheel on the rear of the pin.
I turned a small 13" mahogany platter with a series of beads on the bottom. Then, using the index wheel was able to easily and accurately mark 120 crosshatching lines for later burning. I'll turn this around and do the same to the top.
In the past I would have marked these crosshatches using a homemade "target" which I drew up on a piece of lauan (idea from Al Stirt). I have several of these, each with a different number of segments. Worked pretty well but no where near the accuracy or ease as this indexing plate.
The only improvement IMHO, would be a spring loaded indexing pin. With the pin as it is, the user must turn the wheel CW and CCW moving the pin in and out of the plate holes. Spring loaded would speed the movement.
If you're looking for a well made, accurate indexing plate which also includes the pin assembly, I'd certainly recommend the Alisam. At least after very limited use on my part, though I can't imagine anything on this would wear out or fail.
I've attached a few photos. That's a small Allen wrench laying on the bracket base in photo 3, used for the screw holding the upright to the base.
Mike
Mike
