Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Peter Jacobson for "Red Winged Burl Bowl" being selected as Turning of the Week for April 29, 2024
I found I needed a different type of vice to hold some of my bowls for embellishments, especially the larger ones. So I came up with this plywood and Ironbark with a capacity of 200x200 or 8x8"
The backing plate in 1" plywood is fixed to the metal frames of the bench by Buildex screws, might have gotten carried away there as I used a lot them The locking set up is as you can see just a 1/2" UNC screwed rod. There are a couple plates that slide in order to give some support to the Ironbark jaw
