A little "ADVICE", if you please
Benton, AR
I'm certainly new to this world of spinning wood. What is the best tool(s) to smooth the ridges and bumps in the bottom of this straight-sided box? It is about 4 inches in diameter and 1 and 1/2 inches deep. Hopefully, there is a photo attached. Thanks much.
thumbnail
Well, there is no end to the tools you can have and use. For a bottom like that, I would prefer a negative rake scraper. You can do a good job with a regular scraper as well, which may work better if you hone off the burr. I would want one that has a straight edge more than a rounded edge, more like an L but with an 80 degree angle rather than the 90 degree one as shown. This allows you to get a crisp edge in the corner/transition area.
Benton, AR
Thank you for the prompt response. I have a negative rake scraper and thought I might give it a try. But was unsure how it would act or react when engaging the bottom at what seems to be a 90 degree angle.
using a scraper on the inside do not allow bevel contact Which makes a big catch.
tool rest above center significantly reduces the chance of bevel contact.
NRS would work well To remove the bumps light touch many passes.
a gouge bevel ridding, ring tool, or hook tool cutting from center to the wall will All leave a clean flat bottom.
the Hunter tools would also leave a nice flat surface too.
Benton, AR
a gouge bevel ridding, ring tool, or hook tool cutting from center to the wall will All leave a clean flint bottom.
Thank you!
