Probably would have if they knew they were talking to a lawyer though.
The inspector is the judge and areas can make and interpret code differently. But I find that odd as it would really make it difficult and expensive for spas that require two GFCIs. Some have a separate one for the heater.
I was just pulling you chain a little. I apologize if I have offended you.
Perhaps TW waded this am. de nada.
I did a full r&r on our master bath. Had had a Jaq on a timer (just replacing what was there). Replaced with a Kohler "soak tub" that required two GFCI circuits (pump and heater) as well as bonding and secondary ground. Inspector about drove me nuts as he insisted on visually tracing both circuits from panel to tub before he'd let me close up the ceiling. He actually said that code required "the circuit to be GFCI" meaning from panel onward. BSOM, I'm just follerin' orders.
		 Without the investment in time to thoroughly learn it, it would appear to be open to interpretation.  That said, local governments have some flexibility in implementation.
