WTB: Crown Negative Rake Shear Scraper
Lebanon, Missouri
Cheap and easy to make your own with a grinder, drill, and tap. Mild steel bar, 5/8 or 3/4, from the box store. I ground the insert mount parallel to the shaft. Tried it at an angle like that one, and the shaft needed to be too “square” to the work.
brian horais
Knoxville, TN
www.horais.com
Tony, I would recommend making your own NRS from a standard scraper. Buy a thick one (1/2 inch) to minimize chatter. I used my metal grinder to do the initial grinding and then finished the grinding on my lathe tool grinding setup. The bottom angle is the same as I use for my roughing gouge -that way I always have the angle set up to do touch-up grinds on the NRS. The upper angle (shown in the image) is steeper to ensure the included angle between surfaces is less that 90 degrees. You will notice that I made the NRS two-sided. This lets me use it inside and outside my bowls/turnings in whatever holding direction I need. Hope this helps.
Brian
Alaska
www.tonyperelli.org
Brian
Thanks Brian! Also - I enjoyed your Therming article in the AAW journal.
