WTB: 4 3/4" PRECISION MACHINE SCREW CENTER FACEPLATE.
Precision Machine 4 3/4" screw center faceplates were available from CSUSA about 10-25 years ago, and have been discontinued. I have two of these faceplates, and wish to purchase another one or two of them with a 1 1/4" x 8tpi adapter. I know this is a "shot in the dark", but if you have one of these faceplates you'd like to sell, let me know.
Please do not reply to this thread, unless you have one of these, or know where one is.......thank you.
(Please note that I'm only interested in this particular Precision Machine faceplate......not a substitute. Thanks :D)
Odie I had a thought . You could with your metal skills cut a steel disc and weld a nut to that then drill and weld in a screw
Thanks Gerald, I know you're just trying to help, but did you read the following in the original post?
Hopefully, the original Precision Machine 4 3/4" screw center faceplate I'd like to have will turn up eventually.....
North Canton, Ohio
bump, Odie, I have not responded before as you are very clear as to your needs. Back at the turn of the century I puchased one and to this date I have not used it and probably never will. Only problem for you is back then I had a Delta midi lathe with 1"x8 tpi theads.
