- Joined
- Dec 22, 2006
- Messages
- 7,135
- Likes
- 9,960
For about 5+ years, I've been extensively using negative rake scrapers on my bowl interiors.....after years of thinking they were no different than standard scrapers using both flat to the tool rest. My thinking here, was the tip of the bur is no different in it's presentation, if the standard scraper is simply tipped slightly to match the presentation of the NR scraper.......but, I'm wrong about that, and I do not understand just why this is so. (Speaking strictly here about ground burs, and not manually raised burs, and both used at the centerline.)
In practical use, the standard scraper is noticeably more "grabby" than the NR scraper, used identically at the same angle and height, and flat to the tool rest. This advantage that NR scrapers have, allows for a little more manageable control.....and, is very useful under certain conditions.
I know the NR scrapers have this advantage over standard scrapers under certain conditions......but, I am unable to conclude why this is so.
Here's the question: Why do NR scrapers have an advantage? It just doesn't seem like they should, but there must be a reason that is comprehendible from a physics perspective.
