What's the next toy.. errr tool?
Alpharetta, GA
Second vote for the spike configuration. As Brian says, it's useful. The one on the Stihl is somewhat blunt, but I've never felt it needed to be sharp. Get as long a shaft as you feel comfortable with as it provides the leverage of course. I seem to remember the Stihl came in a couple of lengths, though I could be mistaken. Mine is roughly five feet long sans the point.
West Central, IL
Still haven't gotten the log lifter yet.
However did buy an eighteen inch jet bandsaw a little bit ago.
Now I'll be spending the rest of the weekend doing a shop re-arrange to make room for it. Pick up Monday!
Sydney Australia
Due to moving and downsizing etc I am about to combine best features of both of my lathes. So the smallish layout lathe will be up graded with a motor a three-phase with VFD 240v and variable speed control magnetic base. A bed extension of somewhere around 12-18" havent quite decided yet and a new tailstock. The big lathe had a camlock set up for the toolrest on the banjo still deciding on that, may just keep as it as a spare as it is longer than the current one on the lathe
West Central, IL
Have any pictures of your setup? Are these homemade is that how you are able to vary the length?
Sydney Australia
Will put them up as they occur, currently the lathes are separated from the stand for transport and yes DIY all welded construction
Sydney Australia
Sam here you go, just put the basic lathe back on its stand. Its a little unusual as it has three bed and a 5 legged stand, swing arm motor mount that I have additional springs to increase the dwon would thrust but rarely use them. The short additional bed are for additional equipment such as a swing arm that holds carver gear like a Dremel etc. it al;so allows me to mount the banjo on the operator's side which is handy with the short bed. The new motor will be 2 hp 3 phase 1440rpm which should do all I want. I will be keeping the stepped pulley set up to counteract for the loss of torque at lower speeds.
If you have any questions fire away
West Central, IL
Having the extra ways sticking out like that looks really handy, less crowded on the main bed.
I'm guessing the apparatus that's holding that drill in the background is an item that goes on there? And your fluting set-up.
Sydney Australia
Yes and no, the fluting is laid out on the lathe using my own indexing set up then hand cut later off the lathe. Due to the way I cut the flutes it really would needs a CNC router and thats a bit out of reach on my pay grade. The front way is more used for the banjo as the bed is short 700mm or 27" the banjo has 12" of travel so it can reach well down the bed. The rear way or bed allows me to mount attachments without loss of bed space which is kinda important with 27". Usually a swing arm set with the upright post being slightly above the headstock height. The cross or swing arm is around 36" so it will swing on over the bed if required to carry a variable speed pistol drill for flexible extension for internal sanding or power carving. I have a power board mounted on the tailstock end of the stand for this purpose.
Clinton Corners, NY
Even though I love gadgets, I do not need one of these, as I am well supplied for the sharpening I do on a platform.
That said, this is pretty interesting:
Saw a facebook post from Rob Wallace about that. One of his club members. That looks like a really interesting set up. New and improved my robo rest. It isn't cheap, but considering what metal was doing when I quit making mine, and that I was probably selling mine too cheap, it seems fair to me.
West Central, IL
I can see why someone would want the programmable one over the talon series.
But I'll probably never get to the point where I need a specific grind over what the talon series provides. It looks like it has plenty of variations to me and I'd just use them.
That being said my woodturning budget is too stressed at the moment or I'd be trying one out!
For some reason it's just finicky to me when I switch the platform to the side where the cbn wheel is then I have to find the right angle to grind a roughing gouge or the scraper I'm using. I have gotten in the habit of sharpening which ever tool RG or scraper that I last used so next time it's sharp to start out with and I don't have to set the platform right off the bat. I know... get another grinder to leave set up.... (see third line)
Dave Landers
Estes Park, CO
dlwoodturning.com
That's mostly why I've settled on 3 angles for my platform. For me its:
  • 40 for NRS (both sides) and my SRG.
  • 60 for my bottom bowl gouge
  • 75 for the teardrop hollowing scrapers
I don't use skews enough, so they're not in that list (yet). I've done something similar with my varigrind setups (that is, I don't have to change much to go between bowl and spindle gouges).
I have probably made a few compromises in what angles I use, but it makes sharpening much easier.
I am lucky to have 2 grinders (4 CBNs) so I keep the varigrind setup and the 40 on the better of the two. But before I had 2 grinders, I had 3 platforms each set to the angles above. And I kept a sample square of formica to set the distance between the platform and the wheel so the platform would go back to the same place (thus same angle) each time.
And before that, I made some angle gauges. Some of the various jigs I've made for sharpening are here: https://dlwoodturning.com/tag/sharpening/ - down a ways on that list are the angle gauges and how I lay them out for various angles. Most of my jigs are made to copy a grind rather than to grind a specific angle (that is, I find a grind I like then create a jig to get the sharpening setup back to that point).
West Central, IL
You ever have one of those duhhhh moments?
I just did. Why didn't I think of just getting extra platforms? I see woodcraft is selling them for $35.
Also going to have to try out your design for the gouges with the three holes for the vari grind jig.
West Central, IL
Lee valley ended up having the platforms for $26 dollars. So I picked up one and a beal 1 1/4 spindle tap to get free shipping.
West Central, IL
OK....... tax refund time is in the air..
I know, I know, work with what I got... Ya ya.. but it's tax refund time!
In the quest for greatness...
1. Stihl log hook.
2. another grinder or at minimum another cbn wheel. My rikon 1/2 hp seems to be fine so I'd look at another one of those.
3. 1 1/4 inch spindle roughing gouge. (Thompson, d-way or Carter and sons)
4. start putting together a hollowing system just in case?
5. or be conservative and rat hole some sandpaper and other consumables.
My mindset has always kind of been that it's better to have something and not need it than to need it and not have it.
Obviously I'm not going to buy all of these items at once but I think that would be the order of importance. maybe switch 2 and 3. I've been preparing logs for next years snowmen and a heavier duty SRG would be nice.
What say YE?
Larimore, ND
3 and 5 would be my direction, maybe save for a bigger ticket item down the road, maybe some wood blanks you've not had opportunity to turn before? Sooooo many things, so little time.
West Central, IL
One thing about this hobby... You never have to worry about running out of toys and gadgets you can buy.
I'm pretty set in the wood department. Down the road maybe I'll turn an exotic for a gift or something but for now I have plenty of green wood that I need to get turned into rough bowls to keep the ball rolling.
I did consider adding a ceiling mount dust filter but since I put a big cartridge filter on my harbor freight dust collector it's gotten better dust wise. Now I just need to run it more.
Columbia, TN
Keep an eye out. I bought the Rikon 62-1100 for $350 a few months ago. Regular price is $600. When I see something deeply discounted like that, I usually pull the trigger. Obviously, you have to do your research on every item to ensure it's not junk.
I’ve been using a 1 1/4 crown tool for over 30 years. My wife bought a PN SRG and uses my crown tool.
Don’t see any advantage for the heavier spindle tools.
Maybe if you are turning porch posts but then you would want to go with a continental roughing gouge
If you do the occasional spindle. An Ellsworth ground gouge will go from square to round almost as fast an SRG
Push cuts to depth followed by a pull cut end to end get you to a cylinder quite nicely.
Interesting thing. Not quite what I am looking for though. Still want an X/Y cutter for my mini lathe and box making..... I was at the dermatologist's office yesterday and they wanted to get a biopsy on some weird spot, and after shaving it off, they used a hand held laser thing to cauterize the site. My first thought was that hey, that laser thing could be used for free hand burning/signing/detailing on wood things...... Don't know if any one makes some thing like that or not....
West Central, IL
Only problem is you could probably buy a laser that would cut 1/8 inch steel for what that medical laser costs. Medical field just keep adding zeros.
Orange, CA
It’s called a hyfrecator—it’s not a laser. Costs about $500 used and requires no ground. I used them for 40+ years in my urology office. If it had been a laser, you and the doctor would have worn special glasses. And that would be overkill for removing a skin lesion.
Hmm, still wondering if it could be used on wood..... Always some thing new to experiment with....
Doylestown, PA
You could get a small laser engraver for about 300 to sign the bottoms. Just take a picture of your signature and use that as the image to engrave. You could also mount it to the tool post and use an index to put a repeating pattern on a piece.
More expensive lasers have functions to map out the surface of the material and engrave better on curved surfaces. Others have a 4th axis rotary function.
Here is a Tim Yoder video on doing fractal burning with a laser.
View: https://youtu.be/ZeFQ3j3j3cU?si=Kn0NSQgwASuJI5Oh
Elysian, MN
I always thought a Bedan sounded superficial, like a "lazy man's tool" until I bought one from a retiring turner. Great for cutting mortices and kinda fun for cornering in detail grooves.
West Central, IL
Next tool lately was a one-way spindle steady rest which I tried out today.
I've been making some walking canes and the steady rest makes a big difference.
Technically I bought the bowl steady and then added on the spindle head so you only have to buy one base.
One problem I figured out was it makes me too confident and aggressive in the cuts. The hedge apple I've been using will chunk out when I get carried away.
