Thinking about buying a drill chuck
iowa
I'm Thinking about buying a drill chuck for my tail stock so i can use a fosner bit to drill vases, ornaments and so on. The thing is I don't have a 4 jaw chuck, I glue all my work on. So my question is will this put too much pressure on the glued work piece or should I be ok. I have only been turning about a year and am slowly acquiring the tools and supplies i need. Any advice would be greatly appreciated.
If you have a glue joint that holds wood for turning it should hold for drilling.
Stress will obviously increase with larger diameter and dull bits.
Glue joints I use for Engrain turnings are a small tenon glued into a block on a faceplate.
To put next piece on I face off the glue block drill out the hole for the tenon and glue the new piece in.
So a Jacobs chuck comes in handy or glueing Engrain blanks.
One note: many Jacobs chucks tend loose the taper lock.
I hold the chuck when backing it out
I use twist drills held in a vice grip. This works well up to 1/2" diameter
Need to make a small center hole with a gouge.
I also use a 1" twist drill with a #2 morse directly the tailstock.
For use around a wood lathe, a keyless chuck is a good choice. With a keyless chuck, no looking for the key in the shavings is a big plus.
Mine hangs on the same magnet as my knockout bar, always at hand. What I hate is the key for my sanding chuck is a size smaller. :mad:
ditto!!
I bought a keyless chuck at the Florida symposium a few years ago from Mike Hare at VM Woodworking vmwoodworking1982@yahoo.com
IMHO is the best chuck key or no key available. It actually tightens up a bit when you start drilling and is still easy to open.
Not sure of the current price. I paid about $40 including a "mike's ONEWAY tax" - the extra cost of the #3 M taper.
I keep trying to convince myself that I need one with a #2 for demos.
Where did you get such a thing? I could use something like that.
Thanks.
I bought mine from wholesale tools in Tampa. The store closed last year but the have a web site.
Wttool.com
Most on line tool companies will have them
1" is the largest I have found in #2 M taper about $13 from Wholesale tools.
Larger ones are available with #3 M tapers that fit the ONEWAY.
They do come in handy
John,
Wholesale tools may have one. It does not specifically say Morse taper.
I would suggest you call them before ordering to be sure it's a morse taper.
0101-0370 1" 10-3/4" 2 taper* In Stock $13.80
I may have this very same bit but can't be sure.
Thanks to Jim Mullens it is real sharp.
Houston, TX
Australia
I use Colt forstner bits with their Rotostop MT2 adapter on both the lathe and my drill press. My chuck gets very little use these days.
Ross
