I see several videos on U-Tube where the turner is sanding with wax. What are the pros and cons of this method?
Makes sense. The turner I referred to uses the wax/oil combination from sanding to final finish.I have seen this method and believe it is if you are wanting to sand and finish in one motion especially if a wax/oil finish is desired result...
Thanks
