- Joined
- Apr 27, 2004
- Messages
- 8,678
- Likes
- 5,045
- Location
- Lakeland, Florida
- Website
- www.hockenberywoodturning.com
The problems with post lengths is more not being able to use long posts in lower swing lathes.Hi Bill......There must be some difference. Why else would tool rests be available with different post lengths?
With the longer posts you have a larger range above center.
I only set my rest above center for some scrapers an then it is only a 1/2 at most.
Might get a little more vibration from a short post since ther is less post below the locking mechanism.
Not usually a problem.
Conversely using a long post on a 16” lather ther are two issues.
Banjos with an in-line post hole the rest cannot get below center because they bottom out on the banjo locking rod.
With offset rests the long post is partly useable - the post sticks out the bottom - the rest can be positioned for lots of cuts but the center cannot be moved too close to ways so it can’t be positioned to hollow with the tool on the rest above the post.
