Photographing Finished Turnings
Toronto, ON
I am curious if anyone would like to share any specific advice or show their photography set ups. I am using a small self contained 24" cube table top studio rig that I bought off amazon. It has plastic "seamless" backdrops, 2 banks of LED lights. The lights are moveable and dimmable. I am not terribly happy with the results. It is designed to produce very diffuse lighting. I find the light is too diffuse as it doesn't show texture or depth very well. I would prefer that I could get the background to be more gradated (from light in the foreground to dark in the background) as I see in many of your photographs posted. I am looking to find a better system. Any help would be hugely appreciated.
Sweden
My standard set-up. Modified my photo setup a little to be able to screen off so that the background at the top becomes darker. The bowls look more three-dimensional this way. The background is a roller blind from IKEA painted melange in grey, without gradient. The light shielding is also a roller blind to easily change the height. On the right, I'm holding a piece of styrofoam with aluminum foil on it that acts as a reflector. The fluorescent tubes are four standard 18 W 4000K. I easily set the color temperature with the gray background. If anyone is wondering about some other stuff in the picture, the space also functions as a spray cabinet connected to the chip suction system via filter and only for water-based varnish/paint.K3_05634LRs.jpgK3_05631LRs.jpg
I have several handouts I would be glad to send you if you send me an email. John Beaver has a great article in the current Woodturning fundamentals. You can search for my previous articles in American woodturner. If you need to show texture stay away from the light tents or boxes.
Ponsford, MN
In a previous thread that I initiated I asked for opinions on those fold up cubes like you got from Amazon. The responses I got were decidedly against the them so I am still using my sky blue seamless with common led light bulbs, which the digital cameras don't seem to mind.20009Bowl.JPG
This natural edge bowl was finished with walnut oil and is photographed supported off the seamless on 2 pine triangle strips after learning on a previous photo session that the walnut oil can leave ring stains.
Brenham, Texas
I'm using a really simple setup for my "studio". It is just a piece of fabric thumbtacked to a shelf in my reloading closet. The fabric drapes down to cover a cookie tin sitting on the tool chest that holds my dies and such.
I'm using a Pentax KS-2 DSLR with a fast 50mm portrait lens in aperture priority mode. I use a hot-shoe flash set to 80% power for lighting. I'm still tweaking the settings and lenses to find the best settings but am pretty happy with these results.
I'm not suggesting that you need to spend a couple of grand on camera equipment. A cell phone camera is at the low end of the photography spectrum. An inexpensive digital point and shoot might be worth a try.
Sweden
We all have different taste, but I think that the most important things are:
1 Uncluttered background, without any fold or wrinkles
2 Neutral grey background. Makes it easy to set white balance. Coloured backgrounds always result in a colour cast.
3 Diffuse lighting to avoid hard shadows and reflections
I would say that if you look in any book on famous woodturners, you will see that they almost always follow this rules.
Erie, PA
Dependent on importance, size and time available I can use either.
These are 3 good rules to follow, though there are stunning exceptions commonly seen, especially rule 3. @Marc Banka oak bowl in this month’s challenge is an amazing example of directional lighting, and some of @Donna Banfield use of lighting to emphasize negative space is striking as well.
Toronto, ON
My standard set-up. Modified my photo setup a little to be able to screen off so that the background at the top becomes darker. The bowls look more three-dimensional this way. The background is a roller blind from IKEA painted melange in grey, without gradient. The light shielding is also a roller blind to easily change the height. On the right, I'm holding a piece of styrofoam with aluminum foil on it that acts as a reflector. The fluorescent tubes are four standard 18 W 4000K. I easily set the color temperature with the gray background. If anyone is wondering about some other stuff in the picture, the space also functions as a spray cabinet connected to the chip suction system via filter and only for water-based varnish/paint.View attachment 48194View attachment 48196
Thank you Lennart for showing us your setup! Very helpful. I applaud your ingenuity. You refer to painting a "melange" in gray. I like the mottled effect. Is there anything more you can tell us about how you did this? Was it a paper blind or vinyl? What sort of paint?
Toronto, ON
In a previous thread that I initiated I asked for opinions on those fold up cubes like you got from Amazon. The responses I got were decidedly against the them so I am still using my sky blue seamless with common led light bulbs, which the digital cameras don't seem to mind.View attachment 48208
Good tip about the potential staining Don!
Toronto, ON
Thanks for the details Monty. I am using my phone on a tripod at the moment but I have pondered a DSLR. I'm hoping to find a friend with one that I can at least try out.
Toronto, ON
Good observation Michael. I have checked out your references to Mac and Donna. Thanks!
Sweden
Sebastopol, California
There's another graduated backdrop brand called Flotone, which I've gotten very good results with. I'm planning to switch to a warmer color value on my photo lights. Currently using daylight bulbs (5600k) which are a bit chilly, though plenty bright.
I have the roll of graduated backdrop hanging from the low ceiling over my drafting table. When it's time for a shoot, I unroll the backdrop and clip the leading edge to the front of the table so it doesn't slither off. My lights are on tripods, with an umbrella style reflector and detachable diffuser.
Durham, NC
It’s possible to have better results with the outfit you’re presently using. A real camera would help, but that’s something different all together.
Add directionality by moving your lights into one bank (as tightly grouped as possible) and position them at the near left edge of your box. Adjust the height of your lights to suit.
Try removing that front ‘shield’ and turn off the house lights. Have only the one light source. Removing that shield will eliminate that one reflection, which will increase your contrast.
There are excellent tutorial, as mentioned. A few general thoughts though.
Some directionality is good. We are animals, and respond best when things fit our world. Because we have a sun, we come to expect light to be coming from a place, a thing. Because it (light) has a source, it will create a shadow. Big, small, hard or soft, it’s there with these different qualities. Small light far away (our sun) produces a hard light with a hard, sharp shadow. A big light source such as the light on an overcast day has soft shadows. It’s a big soft box.
A shadow can be inky black, or justly slightly (or not at all) noticeable. That’s controlled by reflectors in the environment, nature’s or ours. These reflections ‘fill in’ the shadows. The shooting boxes are generally max softness and minimal shadow. It’s good for showing what something looks like, but provides no life. No drama. We like drama!
The quality of light, hard or soft is controlled by the size of the source and it’s distance from the object. Smaller and further = harder. Larger and nearer = softer. Hard light = sharp shadow.
Fill light/darkness of shadow is controlled with a second light source. Could be another light, but usually a reflector of sorts. By changing its placement and proximity to the object, one can lighten or darken shadows.
Soft light is easier to deal with, is more forgiving, but not as exciting.
Harder, more directional light, with harder shadows has more drama, shows detail and surface quality. For instance, if I want the chatoyance to sing, I’ll want to be using hard light, especially if my surface is flawless. It’ll really ‘pop’. If you have scratches though, or torn grain, or other blemishes, you and everyone else will see them.
So, it’s not a method — I don’t do methods or recipes very well. So, I leave you with a way to think about light, and what is it that you might want to share, a starting point for your own exploration. It’s so awesome that digital has allowed us to do that so easily.
Sweden
A graduated background or a shielded off upper part as illustrated in my first post, makes your piece more 3D. In this case I also used a reflector to lighten the front.
Another possibility is to fix this in post-processing. Lightroom classical got a very good improvement for masking in the latest update. You can now apply a linear mask, intersect it with the background, reduce the exposure and it automatically darkens the background. The cataloging function of LrC also makes it very easy to search and retrieve what you want. This is the first image post-processed in LrC.
Toronto, ON
View attachment 48248View attachment 48250
That's very cool Lennart. Thanks for the info. I find it interesting that the digital editing with LrC has added only that background shadow and no change to the bowl, but it makes it look like the bowl has more depth and contrast. Thanks for all your effort and discussion on this topic.
Toronto, ON
thanks for the ideas Marc! The mechanisms for attaching the light bars to the structure unfortunately don't allow for much freedom, but I will fiddle around with it.
Thanks for your comments Kalia!
I see you have a Color checker chart in your set up. Do you find it helpful?
Yes, I use it to create custom color profiles for my cameras. The profiles are used by Camera Raw. I believe that the custom profiles will also work in Lightroom.
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
And one you wrote some years ago
Gaylord, MI
Hi,
I'm just nee to photographing my pieces and would love to read your material.
Many thanks in advance.
Ivanewitt@gmail.com
Bournemouth, UK
I generally use one of these light tents. I don’t use any lighting, I just wait for an overcast day and use it outside. Failing that I have a room in the house with good daylight that I sometimes use for small stuff.
Rosman, NC
Thanks everyone for your responses. John I'll check out some of your references. Marc I especially liked your explanation of natural light and the effects. Gives me a better understanding of how to emphasize what I want in a photo.
