- Joined
- Dec 22, 2006
- Messages
- 7,140
- Likes
- 9,994
At one time, a couple decades ago, I had thought all vibration created and felt at the lathe could be dealt with by absorbing it through the addition of anchor bolts, weight, sand, metal, whatever.........but, this just isn't so. I'm relaying this information so that if there is anyone else thinking along the lines of what I once did, they could be redirected to a different way of thinking about this subject.
Adding weight, mount bolts, etc., to your lathe will help eliminate the kind of vibration created by an out of balance condition.......or, unequal centrifugal forces, simply by not allowing the lathe to move. That's it, end of story..
There are two types of vibration in lathe work......as mentioned, there is unequal centrifugal force created by an out of balance condition, and then there is that vibration which has as it's root source, contact between the wood workpiece and your cutting tool.
That I know of, there are only two attempts at a mechanical fix to the vibrations created between wood and cutting tool.
One of these is lead shot in the handle of your tool. Honestly, I've never tried this, but reasonable deduction will conclude that lead shot in the handle will not eliminate vibrations created at the cutting edge........all it will do is absorb the felt vibration in your hand. I consider this a gimmick.......If there is vibration being created, then deal with it at the source, not how it's felt in your hand.
The other mechanical fix to vibration, is a bowl steady.....(or, using your fingers.) I have a couple of bowl steadys, and they do work......but, only to a point. They work by reducing the flexing action of the wood itself. I stress that bowl steadys cannot completely prevent vibration, but they can certainly prevent it sometimes, and at other times, reduce it.
Bowl steadys are a worthwhile thing to have.....
.....and, adding weight, and/or using anchor bolts are worthwhile things to do, as well.......Not much you can do about preventing the forces applied to your lathe by an out of balance condition, but you can prevent the resulting movement of your lathe with weight and a solid mount.
The most important point in this post is to stress that.....The best way to help eliminate, or reduce any vibration created by the cutting action of tool to wood, is to have sharp tools presented well.
