- Joined
- Jan 27, 2005
- Messages
- 12,903
- Likes
- 5,194
- Location
- Dalworthington Gardens, TX
- Website
- pbase.com
i recently purchased a set of McNaughton Mini coring blades from Craft Supplies with the intention of coming up to speed by coring small bowl blanks. I already own and have been humbled by the jumbo and standard size blades. When I received the mini blades I was surprised and somewhat dismayed to see that the curvature of the blades was hardly different from the standard blades. Here's an iPad shot of the mini blades.
The smallest blade has a radius of 3¼" compared to the small standard blade which has a radius of 3½". While I was expecting a slightly smaller radius, this blade has an acceptable curvature for small bowls.
The curvature of the middle size blade has a radius of 5⅜" which Is "interesting" because that is a slightly larger radius than the middle standard blade. The radius of the middle blade of the standard set is 5¼".
The real surprise is the large mini blade which has a curvature of about 12" radius. It almost looks like a straight blade that has a slight kink. By comparison the largest blades of both the standard and jumbo sets have a radius of 10". I'm not sure how this blade can be used as part of the mini set where the target range of bowl diameters is 10" and under. This has caused me to have second thoughts about also getting the micro blades. After further thought I suspect that this blade has a specialized application for cutting very tall cores and might be useful for something like a set of tall nested natural edge bowls cored from a burl.
The mini blades are slightly thinner than the standard and jumbo blades and are only 3/4" tall vs 1" for the standard blades and 1¼" for the jumbo blades. They also cut a narrower kerf that is only ⅜ inches wide. My thoughts are that the small mini blade would be the most useful of the three. I suspect that I might not ever use the large mini blade, but never say never. I'm still recovering from back surgery so I'm still just mentally turning while awaiting the official "go ahead". I would like to hear about the experiences of others who have used the mini blades.
