Lathe for sale: Vicmarc VL300 CS Series Longbed Variable Speed. Appleton, WI
Status
Not open for further replies.
Appleton, WI
Description:
The Vicmarc VL300 EVS lathe is capable of holding work up to 24" diameter, and is powered by a variable speed drive with a 3 h.p. motor that handles large work with ease. The lathe has a heavy cast iron construction and a steel base which dampens vibrations.
Features:
-Electronic variable speed drive (reversible)
-Remote switch box
-Vibration absorbing cast iron construction
-Solid 5mm thick steel stand
-Wide footprint for stability
Specifications:
-Swing Over Bed: 24"
-Distance Between Centers: 48"
-Indexing Holes: 24
-Headstock & Tailstock Spindle: No. 2 MT
-EVS Speed 10-3000 rpm: 3 Speed
-Toolrest Post Diameter: 1"
-Length: 72"
-Depth @ front base: 27"
-Height to spindle center: 45"
Includes:
-Live Center
-Tool Rest 12"
-Knockout Bar 18"
-Drive Dog
-Spanner
-Owner's Manual
Price:
When I purchased the Vicmarc VL300 CS Series Longbed Variable Speed from Craft Supply USA in 2011, the cost was $5800, This longbed model is no longer available. The closest comparison would be the Craft Supply's Vicmarc VL300 EVS Shortbed ($6500) with the addition of the 40" Extension with leg ($1330), for a total of $7830. I will sell it for $4,700.
Buyer is responsible for pick up/delivery arrangements.
If you are interested in buying this lathe, but want additional information, please contact me at lmercier@new.rr.com or call 920-739-3511.
Status
