Laguna Revo 18|36 dimension request
Silver Spring, MD
discord.gg
I'm going to be doing a demo later this year on a Revo 18|36. In order to properly set up my devices, I need two measurements I do not currently have.
1. The width of the bed
2. The width of the ways opening
Thank you in advance if you can provide this information.
Beavercreek, OH
www.ovwg.org
Our club has an 18|36. I can try to measure it when I'm there next week.
Melbourne, Australia
I have the Revo 24-36, the beds are the same, as are all the bed accessories.
The steel ways on mine are 79.3mm wide, the gap is 50mm the overall width is 208.6mm.
If you need to slide the banjo or anything else, then ensure the steel is clean, I use Dry PTFE WD40, really makes things slide.
Hope that helps.
Silver Spring, MD
discord.gg
Hope that helps.
Thank you!
