Homemade Vacuum Pump
Southern Utah
Several months ago someone posted how to make a vacuum pump from an old refrigerator compressor. Would anyone know where that is, or know how to do that?
B
BigDan
Guest
Remember to have the freon recycled
It's important!
I would start checking with a refrigerator repair center or a HVAC dealer.
Annandale, New Jersey
Wyatt,
You do want to stay away from refrigerator compressors as they are too small and will not move enough air. I use the compressors taken from 50+ pint dehumidifiers or larger window A/C units. You can usually get them for free by diving the dumpster at an appliance repair shop or simply asking the guy to save you one or two. As mentioned in my old post, the circulation fan from the appliance makes a perfect cooler to keep the compressor from overheating.
As you can see in the old picture, I use two compressor units. That's because these things only move a bit more than 2 CFM. While ok for small lathes and sound wood, 2 CFM won't compensate for porous woods or larger pieces that cause the ring seal to flex and leak during a cut.
You should also make some provision to capture or deal with the fine oil mist that the compressor will emit during "open" operation as you don't want to be breathing oil. :p I made a condenser coil out of 5/16" soft copper tubing, but you can make a "demister" filter by running your exhaust tube into a coffee can filled with clean steel wool. You can also simply run your exhaust line outside.
Lastly, don't forget that you still need a vacuum gauge and bleeder valve in your rig so that you can measure and adjust the amount of vacuum you're using. Too much pressure can easily crack or implode a thin turning. :eek:
Good Luck. Have fun.
Southern Utah
Thanks Mark.:) I will try that way instead. I just heard a little about using the compressor out of an old appliance and assumed it would be a fridge.
West Tennessee
www.chuckswoodshed.com
Vacuum pump... another approach
I built my vacuum chuck using plans Steve Schlumpf developed and posted on Sawmill Creek. You might find some good pointers on things like the bleeder value, filters, etc. I'm really pleased with mine. The total cost was $200-$300. I didn't keep an exact track of the cost.
Here's the link http://www.sawmillcreek.org/showthread.php?p=851838#poststop
