History/Background on Continental Gouges
Cincinnati, OH
Curious about the continental gouge - how/why was it developed? Where is it more common than the more common "American style" spindle roughing gouge?
After reading a couple years ago it could yield a fairer convex or concave curve than a spindle gouge I purchased a small one and found that to be true. The American style SRG also can yield a fairer curve than a spindle gouge, but doesn't fit the hand as well and is heavier. Both the continental gouge and American style SRG are forged. Wish I had purchased a larger one
Lebanon, Missouri
The continental style was the original design, though I dont know when it came about. Forged from flat steel before milling machines were around to carve the flute out of bar stock.
I don’t find them much different to use than a bar stock spindle gouge, except the vibrate at less overhang. I have 3/4” & 1”, and they are good for fairing slighter curvatures. They are not as stiff as an srg, and neither is very strong with the tang for the handle.
I would think that the continental style gouge was easier to forge than the more standard SRG, which is pretty much half round. They were used on bowls a lot then too since there were no 'real' bowl gouges. I do have one small continental gouge, and one big one. Got the big one just because I am curious....
This is from Roy hild
The traditional forged spindle gouges were forgotten as well, as all the makers adopted the milling process to make gouges cheaply. Now everyone makes gouges by milling them out of round section material. I am not so sure that it was such a good idea to make spindle gouges out of round but we are all used to them. The recent resurgence of the forged HSS spindle gouge shows how much better the flatter shape is. Both Henry Taylor and Robert Sorby now make some really nice forged HSS spindle gouges. But why does Robert Sorby call them the "Continental" shape?
Lebanon, Missouri
If someone wants to play around with larger continental gouges, 3/4& 1”, this set of harbor freight tools has them, they are hss, and are over 60 Rc hardness (I have a set from ~12 yrs ago, tested hardness with Rc hardness test files). I still use most of the tools (especially to try new grinds etc). One of the hf “gems” IMO.
WINDSOR DESIGN High Speed Steel Wood Turning Set, 8 Piece - Item 61794 / 35444 https://hftools.com/app61794
Doylestown, PA
I think harbor freight is discontinuing that set. I have it too and they work well enough while being cheap enough that I don't mind trying a new grind. Looks like they have a new set under their Bauer line to replace it.
Denver, CO
www.studiocsh.com
I recently started using continental/forged gouges and they are indeed wonderful for those flowing long curves. Dan, you can still get yourself a large one. Hartville Hardware (also the supplier if you search them on Amazon) has 1" and 1 1/4" Crown forged gouges. I picked up both, as well as a 3/4" Crown in M42.
Sydney, Nova Scotia
I have one, a Henry Taylor HS 41 3/4" spindle gouge. I hadn't even realized or given it much thought that that was what it is. It was part of a set I bought thirty years ago from Lee Valley when I set up my shop. Works fine and I am used to it. I will have to pay more attention to any differences between that and round-bar gouges. Taylor still makes it.
Bournemouth, UK
It may be that they never actually stopped making forged gouges in countries like Germany?
Edit: Kirschen have been around since 1858 so I suspect they’ve been making forged gouges for many years. Forged spindle gouges work just fine, so why stop making them?
Adelaide Hills, Australia
I have one, a Henry Taylor HS 41 3/4" spindle gouge. I hadn't even realized or given it much thought that that was what it is. ... Taylor still makes it.
For reference, here is the flute profile on my 1-1/4" HT
Apologies for image quality. It was taken 15yrs ago before better photos could be taken with your mobile phone.
Randy Anderson
Eads, TN
www.etsy.com
Good thread. Got me motivated to get a "real" one. A while back I repurposed my 1" SRG into something very close to a continental gouge and use it all the time for shaping the outside of large hollow forms. After some basic rough form shaping with the traditional 2" SRG I use the modified 1" to work very close to final shape. Still have to be a bit careful with it but it's a great tool for taking off a good bit of material with decent control over long curves on a 30" hollow form.
