- Joined
- Dec 22, 2006
- Messages
- 7,116
- Likes
- 9,836
At 3:55, it says the headstock is more stable if positioned at the end. Just wondering if those of you who have sliding headstocks find this to be true.....
Craft supplies no longer carry Laguna lathes. I asked why and was told by them that even though they make really good lathes the customer support was not where it needed to be so they could not longer carry their lathes.
To measure vibration you can put a half full water bottle on the ways
I thought that the bed looked awfully lightweight for a lathe with a 24" swing. The leg castings looked really rough. The tailstock seemed like something that belongs on a much smaller lathe. They claimed that the motor is 3 HP, but the size seems way too small and I would have guessed 1½ or 2 HP. The inverter is a bottom of the line Delta S1. Finally, I don't like the tool rest clamping mechanism. I can see the possibility of difficulty removing or inserting a tool rest. I can also see the possibilities of the toolrest slipping while turning.
Given the lightweights bed, I can see why they recommended parking the headstock over the legs. I position the headstock on my Robust wherever it is the most convenient.
In summary, I think that the Laguna has way too much swing for for a lathe of its build. A swing of 16" seems more appropriate to me.
Thanks for this idea, Al......will be trying this today!
..... I wonder if using alcohol (or some other thin liquid) might be better at showing the vibrations.....?
Bill,
As a “newer” woodturner don’t know if I am qualified to respond or not. As a recent purchaser or the Laguna Revo 1836, I would like to share my thoughts.
I recently upgraded from a Delta 46-460 to my new Revo. Like many turners, I dreamed about the Robust, Oneway, and Powermatics, Vicmarcs, etc. However my budget gave me a reality check. I researched quite a few mid-priced lathes-Jet, Nova, Grizzly, Laguna, etc. I talked to several turners in our local club. I also got to test drive some of their machines. For a few months I aggressively searched the internet and club websites, but couldn’t find a used lathe that fit my needs, close enough to home. (Like you I would have a hard time purchasing a lathe, sight unseen.) The Laguna was on sale and so I made my decision. It was delivered to my door for $75!
I believe the fit and finish is comparable to the other lathes I researched. The internet reviews were very good. I invited one of our most experienced turners from our club to visit and give me his honest opinion (he happens to own 5 different lathes including a big Oneway). He told me he was very impressed with my lathe, considering it’s price.
Finally, you should know that I have a small shop. I moved the headstock in so the motor wouldn’t hang out off the end of the bed, taking up more space. I experienced no vibration. Granted I haven’t turned a large, out of balance bowl, but lathe runs smoothly. I can’t remark on the electronics because I am not an engineer.
So based on my limited qualifications, I would recommend anyone looking at a mid-priced lathe, give consideration to the Laguna. It may not be the best lathe out there, but I believe you get a lot of value for the money.
Thanks,
Jon
The narrator in the video says the bed is welded steel, looks more like cast iron.
From the video one thing I really didn't care for is the spring loaded spindle lock, a bad idea.
Thanks Bill,Jon,
Your real world experience is certainly worth a lot more than my opinion since I haven't actually used a Laguna 2436 lathe. I'll admit that I've been spoiled by my Robust AB.
Also note not everyone has that acute sense of touch Odie does so may not feel that vibration.
Well here's my 2 cents. My last lathe was a Delta 46-756, 16" over the bed (steel ways on stamped steel legs), 2 HP with electronic variable speed. And the best part was that the headstock slid along the entire length of the bed and I used that feature quite often when I was evacuating the inside of a bowl or hollow vessel. Because the substructure was stamped steel and did not weigh as much as a cast iron PM, I added a stout shelf below the bed upon which I put about 300 lbs of concrete (in buckets). I had very little vibration.View: https://youtu.be/9O5mpBVJqeE
Well said Al, I like to add, what I always tell my wife when I buy the best possible tool, you get what you paid for. When I dont buy the best I always end up getting it later, not to mention that they should last longer.Differences in Lathes are comparable to differences in cars.
Like cars most lathes will get you where you want to go.
Like cars they have different capacities and different power.
Like cars the “better” ones are more pleasant to use.
And high performance can make the trip faster for good drivers and dangerous for unprepared drivers.
A few are “unsafe at any speed”
That explains it, a few weeks ago I had to go to Costco for new couches, lolAnd, although unspoken, you automatically have given her the green light for new furniture and redecorating project.
Don... Living the good life in God's Country (The Texas Hill Country)More expensive lathes have more features, but they won't make me a better turner. I'm better off with my $2500 lathe and $4500 tooling than a $7000 lathe and no tooling.
To me, the vibration issues on large pieces come from how far off the headstock spindle the piece hangs. With the Vic, the mount is almost right on the headstock tower, so the chuck jaws (Vic 150) would be about 3 1/2 inches off the tower. On my ole PM 3520A, it was off a bit farther, so with the chuck and bowl blank, the chuck jaws were at about 4+ inches (can't remember exactly) off the headstock. With my AB, that mounting point is about 6 3/4 inches. With the Laguna, I am guessing that the jaws move out to 8 or 9 inches.
I don't follow what you are measuring. Is it the distance between the front and rear bearings? Probably something else, but would like clarification.
