Who thought that talking about sandpaper would generate so much friction? I guess the bottom line is what abrasives do the best job, regardless of their composition, backing, etc. My skills have improved somewhat since I first aked about sandpaper back in March and have found that the right amount of pressure is as important as the paper itself. Also power sanding and sanding off the lathe have solved a lot of problems. Experience wins out in the long run, right?
It's also a question of what abrasives work best on different finishes. I use mainly spray lacquer as a finish and have had some success with sanding pads up to 320, finishing off with auto polishing compound. Any comments on that without getting overly excited?
Thanks.
Thanks.
