Electric motor HP for Beall Buffing?
Lower Alabama
I want to use an electric motor for my Beall Buffing stuff. I have a 1 hp 3450 rpm for the mops but need a slower speed for the 8" wheels. Yes, I also use the vs lathe.
If you were buying a 1725 rpm motor, what HP would you get?
Ponsford, MN
If you could find a Delta motor from the 1950's and 60's they had the shaft extending out both sides like a grinder motor. The the unused end had a cover on it that could be used on either end. My first Delta band saw had one like that in 1/2 HP and after installing a height block 1/2HP wasn't enough so i found a 1HP motor. The double shaft motors are reversible and mine is still in use with 2 honing wheels mounted.
Lower Alabama
I think a treadmill motor would work well for this. Pretty easy to find people giving away treadmills on Facebook or Nextdoor
Kurt, I have never messed with one. What is the typical horsepower? I need to look into this idea. The speed control would something that may be very worthwhile.
Bournemouth, UK
Traditional Buffing machines have a Pigtail on each end like this. It’s quick and easy to change mops without any tools.
I just mount a Pigtail in my Chuck though. Pigtails of a suitable size are only about £7 and of course you have variable speed. I never go above about 1500 rpm.
Arnold, CA
Alan, I think the one I put in my old Walker Turner lathe said it was 2 or 3hp-I am pretty dubious of that but it was plenty of power to rough out bowls from chainsaw cut blanks. Richard does bring up a good point about the shaft/spindle interface though. I'm not too sure what you'd need there for buffing, I just ground a flat on the shaft and found a pulley with the correct bore size (an alternator pulley from a ford truck) and drilled it for a set screw.
The wiring is pretty straightforward if you are comfortable with electrical. I can find and send you some youtube videos on setting up the speed controller if you decide to mess with it.
Lower Alabama
Kurt, thanks. I have a machine shop so a bit of machine work is not a problem. I will keep my eye out for one. Yes, 3hp should be plenty! :p
Elkton, Maryland
These are a pair of Red Wing buffers that I used previously. They were originally mounter in a hooded cabinet, the bottom half of which was a dust collector. Unfortunately, the cabinet was damaged beyond salvaging. They are 1/2 hp, 3450 rpm, single phase motors. They have the arbors for quickly changing the
This is the buffer that I use now. It is a Cleveland Armature Works (out of business since around 1940) buffer. It is a 1 hp, 1800 rpm, three phase machine. The only difference between these machines, is that the Cleveland, being floor mounted with extended arbors, offers much easier access for larger bowls. I cannot imagine stalling even a 1/4 hp buffer.
Ponsford, MN
This buffer would possibly work for the Beal buffs, but you probably have another better source for buffs. The buffer could be driven with a VFD that would act as a phase converter and a variable speed controller, and that may be what you have already done, since most home shops do not have 3 phase power available.
The Beal buff system appears to have 3 buffs on a single shaft, which would not be work on the inside of a bowl so maybe you could find round buffs that would fit on the pigtail shafts of your small ones.
Bournemouth, UK
Mops to fit standard pigtails start at around 3” diameter so small enough to polish the inside of quite small bowls. Mounting several mops on a shaft can obviously seriously limit access. We have the Beal system over here but the mops are 3X the price of a specialist supplier like this:
Dave Landers
Estes Park, CO
dlwoodturning.com
That is one option. Looked like a good idea - #2 MT in the headstock end and dimple for the live center cone in the other. So that's what I originally bought. But the 3 buffs on one shaft really limit what you can do without running into the adjacent wheel (or head/tailstock - or even the lathe bed). Probably good for smaller things
I kept the 3 wheels and made inserts (the wheels that come with the single-shaft kit have larger arbor holes than the singles), put a bolt thru each and got a "Hold Fast buffing extender" so each wheel threads on and sits well away from the headstock. If I need room, I can swing away the tailstock and slide my headstock to the end of the lathe...
Elkton, Maryland
My buffer, pictured above, has the longer motor arbors. The buffing wheels are held between two washers. As on a grinder, one is nut LH and the other is RH. I leave one 8”, stiff buffing wheel on the left for use with the Beal Tripoli bar. (I leave this one in place because it is the LH thread nut and I do not want to misplace it.). On the RH side, I switch between the white Diamond and carnuba wax wheels. Switching takes less than a minute.
With longer arbors and 8” wheels I can easily reach the bottom of most any bowl that I turn.
As a note to Dan up thread, if I found a high speed extended arbor buffer or grinder in three phase, I would certainly purchase it and use a VFD for power and speed control. My 1800 rpm buffer is perfectly happy on the rotary phase converter.
