I'm making segmented bowls / vases. They usually have anywhere from 8 - 15 rings made up of either 12, 16, or 20 segments each, depending on the style I'm making. It is (for me, anyway) a lot easier to glue a ring in place, turn it, glue another ring, etc. rather than gluing the whole shebang up in a press and then have to reach inside to turn the interior.
However, my concern is drying time for each ring. What I've done in the past is to fasten the solid bottom disk to a faceplate with a paper glue joint, then the next day true up that disk and then glue on the next ring. The following day I turn that ring's interior, gradually building the inside bowl shape. Then I glue on the next ring. The next day the process is repeated, etc. until all rings have been glued on. It works great but.... I wind up spending a lot of days waiting for the glued-on ring to dry.
I'm using Titebond II and my materials are usually maple, walnut, and padauk. Would it be safe to glue on a ring, say at 9:00 am and then around 4:00 in the afternoon (or maybe after dinner) start turning it? Will the glue cure enough in those seven hours?
