Correct sequence for using sander sealer and abrasive paste.
Invercargill, Southland, New Zealand
Hi, new to this forum and need som advice.
I make my own sander sealer and shortly my own abrasive sander.
I assume that I use me sander sealer, then the abrasive paste, followed by a wax polish finish.
Can someone confirm that is the correct sequence.
Thanks,
Graeme
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
Welcome to the forum. Your steps sound about right. I use an abrasive paste on my threaded boxes. Not sure what it has in it, but I do not have to use an oil such as Walnut or Danish oil. I do not use the process you mentioned with big pieces, such as bowls. Only on my smaller work like the boxes. There are literally hundreds of ways of finishing your work. Try it this way and see how it goes. What are you planning on using it with?
Bowls, candle holders etc.
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
I’m a new turner - how come the abrasive particles don’t imbed in the wood, or do they?
They will, but the real item to consider is what the final products use is and what the final finish is.
The abrasive paste is going to have some sort of carrier, often a wax like compound, which makes it only compatible with that type of finish.
But the question I am guessing has to do with the final use, if it is going to be food use, don't use an abrasive paste, period.
Iota, LA
food for thought.. if an home made abrasive paste is made from beeswax, mineral oil and a food grade diatomaceous earth wouldn’t it be considered food safe?
I'd say so. D.E. is used in some home remedies , Mineral oil is sold (food grade) at pharmacy as a laxative, so there's nothing particularly toxic as a whole - only issue might be in how clean the combination is kept (and how clean it is when it is made).
Larimore, ND
D.E. is only dangerous if you breath the dust. I spread it lightly on the floor in my coup and wear a mask while doing so.
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
Probably.
Anyone have an idea of what micron size DE is?
Probably.
quick google search:
They average only 5 to 20 microns in diameter, yet have a surface area several times greater than any mineral with the same particle size. Diatomaceous Earth Uses As a dust against fleas, lice and other external pests on dogs, cats, and livestock. Use full strength as a talcum powder to rub into dog or cat coats.
Steve Worcester
Admin Emeritus
Plano, Texas
www.turningwood.com
I guess it depends on what you want to do with it. The inconstancy in the particle size in this case may be an issue, but 20 micro is the equivalent of about 1000P or 500 CAMI abrasives and 5 micron would be about 4000P or 1500 CAMI.
Thanks,
Graeme
I don’t use either of those products. I don’t think that sanding sealer is necessary on most woodturnings. Abrasive paste would be used to shine the finish, but the downside is that it doesn’t level the surface so it highlights tiny imperfections. I wouldn’t use abrasive paste on bare wood because some of the grit will forever be embedded in the wood. I finish the finish by sanding with fine grit sandpaper and a compliant backing pad with increasingly fine grit to achieve the desired level of shine.
Erie, PA
I sand to 280 or 320 then use the sanding paste, after putting on a healthy coat of the sanding paste I run the lathe as fast as it will go and start wiping with paper towels pressing harder as I go. When this hard pressing turns up no more color on the paper (I feel at this step the finish is equal to at least a 1000 grit and there are no visible scratches) it is ready for the wax finish where I use the exact same steps as the sanding paste. The finish is a soft glow and handling leaves no finger prints.
Ashland, OR
I’m assuming that use of an abrasive paste with wax means you cannot use a penetrating oil as your final finish? I stopped using abrasive paste for that reason. Is my thinking correct?
Spartanburg, SC
A couple of thoughts: 1. I agree with Bill Blasic that no sanding sealer is needed with any abrasive paste I have tried. It just feels like a waste of time. 2. You absolutely can use any kind of oil you want directly over abrasive paste after you clean off the residue with a dry paper towel while still at burnishing speed. I have used TruOil gunstock finish (essentially a wiping varnish), the various Tried and True oils, walnut oil, and I'm sure some others I have tried and forgotten. They penetrate and set up just fine even with multiple coats burnished in on top. Sometimes the Beall progression on top of that if I want serious shine. I have pieces all over the house in these various finishes, and they have held up flawlessly. Try it, and I think you will be surprised.
Bournemouth, UK
I don’t generally use the stuff but I have read you can use it on bare wood. It can also be used on wood that has had sanding sealer applied to it. I gather from that, that is up to the user to experiment?!
Randy Anderson
Eads, TN
www.etsy.com
I use abrasive paste on all my hollow forms and traditional style bowls. My understanding (not experience) is you can put just about any other finish over it assuming you get the residue off. I use shellac as my goto finish over it all the time but haven't tried anything else. I did try oil over the paste but didn't feel the oil really added anything. The paste seems to add the same tones and color to the wood that the oil would have. I apply it with the white 3M pads and use the grey or a clean white 3M pad as my final buffing pad to get all the residue off I can. I've never really tried a sanding sealer other than shellac which is often used as a sealer but, that's not how I'm using it.
