For hollowing I use several tools. I have a Simple hollowing articulated setup for the neck and first 5-6 inches. Easy to control and get started with. For drilling the pilot hole I use a Milwaukee switchblade 2 9/16" bit. Drill some, hollow some, drill some, hollow some otherwise you end up with a corkscrew hole in the bottom that is near impossible to deal with. I use a Clark steady rest. For the main hollowing I use the Clark 1 1/4" boring bar setup with either cupped, round carbide or teardop HSS cutters. Depends on the wood. I also use a Roly Munro tool with the shielded cupped cutter for some of the work and cleanup down to as far as I can reach with it. Again, depends on the wood a bit. For the outside turning it's just a big spindle roughing gouge, spindle gouge and scrapers, and several wheelbarrow loads of shavings. Net, I'm still new at this and learning.
