I am in a mental fix right now. I have a question or two for all you tinkerers.
In the middle of June of this year I cut down a madrone tree (part for firewood and the trunk for turning). I took the turning chunks home and rough turned them into open bowls, and then boiled them for 3 -4 hours. I took them out the next day and started to let them dry. I checked for cracks and put a little CA glue on the cracks that appeared over the next 2 -3 weeks. Then everything seemed to be stable. The bowls have been on the floor of my shop all this time. Then about July 30, I decided to weigh the roughed out bowls. Wrote the weight on the bowl with the date. I have weighed them every couple of days since then. I use an accurate scale - to the gram. Over the last couple of days the bowls have not lost any weight and are only about 5 grams off the original weight.
Question - Do you think they have dried?
Thanks
Hugh
Thanks
Hugh
