  • Congratulations to Scott Gordon for "Orb Ligneus" being selected as Turning of the Week for January 20, 2025 (click here for details)
Winged Bowl
Ontario
my most challenging piece Maple and walnut. not sure I like the lid I may make a maple one. what do you think with or without the lid
These are tough shapes to do well.
Great work for an early try.
The surface looks nicely done.
Consider a thin lid. I like lids that continue the curve of the form.
Did you do this with waste wood, or as a rectangle?
with the wings being thinner towards the center, you get flex at that point, work the wing thickness down from the outside towards the center and you will get the walls thinner. Don't like the lid as the others say, or the Jammie pants.
A nice bowl without the lid or a box with the lid But I also don't think the lid of the box looks right as said a light lid with a finial would set it of
.not to late to change it and make it into a great box. Just my thoughts 1 persons opinion.
Ian
I believe that the variation in thickness isn't as great as the pictures seem to show, but a straight cut intersecting a curved surface can create that illusion. There are a couple ways to deal with that. One is to have the edge a constant width while the thickness varies. The other is to change the shape of the wings so that the curve is more gentle and continuous from end to end. I would favor the second one because continuous curves serves to unify the whole piece while the first option results in separate elements joined together.
If I were to turn a winged box with wings that have a continuous curve, I would also reflect that same curve inverted to shape the box and also in the curvature of the lid.
Sean,
What the others said..........plus lose the point on the bottom of the bowl.
Good first go at it. My first one ended up with two wings sailing across the shop.🙂
Be sure to wear a face shield.
Don
