I'm no science writer Richard but.........
Resin is a plant product mainly from coniferous trees. It has many uses, but its use in varnishes and adhesives is of interest here. Today, more importantly, the term is used for synthetic substances of similar properties.
“A drying oil is an oil which hardens to a tough, solid film after a period of exposure to air. The term "drying" is actually somewhat of a misnomer, since the oil does not harden through the evaporation of water or other solvents, but through a chemical reaction in which oxygen is absorbed from the environment (autoxidation). Drying oils are a key component of oil paint and many varnishes. Some commonly used drying oils include linseed oil, tung oil, poppy seed oil, perilla oil and walnut oil.â€Â
“Urethanes - Ethyl carbamate (also called urethane) is a substance first prepared in the nineteenth century." When combined with resins it becomes a “finish†or more commonly a "varnish." "Urethane itself is: (NH2-COOC2H5) and is not a component of polyurethanes .â€Â
Polyurethane varnish is a hard, abrasion-resistant finish. Since “poly†does not penetrate the wood very deeply it is often combined with oils or “oil modified†to insure depth of penetration or (bite). Without this oil poly would flake off if dented, heated, or subjected to shock. It should be added here this is where the term "propitiatory resins and oils" enters the picture. Only the manufactures know exactly what is in that can.
This information is just a drop in the proverbial bucket. I 'm still unsure what the term “urethane oil†is in today's parlance. The old saw “even a blind squirrel finds an occasional nut†applies here. I'll keep looking and maybe I'll get lucky.
