• It's time to cast your vote in the January 2025 Turning Challenge. (click here for details)
  • Congratulations to Alan Weinberg for "Elm Burl Bowl" being selected as Turning of the Week for January 27, 2025 (click here for details)
what do you folks use to mark on a natural log surface
Canton, GA
I have finally gotten to rounding some logs into blanks for my lathe. I have templates I place on the logs so I cam determine the proper size for a blank, but I don't know what kind of marker will mark and outline on the log surface. I can tell it definitely isn't a pencil--I've use a 'regular' sharpie and that does OK but doesn't make good mark, that is easily visible when sawing up the blanks.
Appreciate any input/feeedback
I use wood crayons yellow or orange from the farm supply store.
Leave a couple in the chainsaw case.
They are tougher than the kids crayons which should work
Mostly I trim an end off the log and put it on top of the log and use the diameter as guide for cutting.
Chainsaw does a nice job of marking. Use a 16d nail to hold the template, then knock off the corners of the log with a chainsaw. Plenty accurate for me, even if I bump the template with the saw.
When cutting a log up for bowl turning blocks I measure the diameter then add a couple inches and lay a small stick to mark the cut and proceed to cut it off then if it will fit on end on the band saw I cut through the pith. The next step is to put the cut face down and pick out the right diameter plywood disk from my stash and position it and hold in p[lace with a nail then cut the corners off on the band saw.
Thanks folks, if I wasn't clear I'm marking precut logs for rounding into blanks on the bandsaw! I think I will get some chalk and a couple grease pencils....
For rounding in the bandsaw I use discs of hardboard.
I pick the center of the bowl - usually on a line above the pith.
If it will be a naturaledge bowl or natural,edge HF I drill a 1.25” hole with a Forster bit for the spur drive.
I anchor the disc to the center point with an awl.
This is a NEbowl,from a crotch
that's probably worth a try Hockenberry, I've been leaning to a marker cause I figured I'd cut the template--DOH!
The templates are hardboard. I have them in 1” intervals to 10” then 2” intervals to 16”
I try to cut about a 1/4” outside the disc.
They do get trimmed a bit here and there. The still stay close to round.
The 10” disc can always become the new 9” disc.
But they last many years.
Hello Al. I couldn't help noticing your blade. Much thinner than what I have been using. What size are you using, and how many teeth? Thanks in advance for your reply. Aloha
My favorite blade is a 3/8” 4 tpi skip tooth thickness .025”
The place I deal with gets the Morse blades
That one may be a 1/2 4 TPI which I also use
Our club does a bulk buy and they,all have to be the same blade stock but any length.
They get the 1/2” so I usually get a few blade from their order.
