Going to jump in assuming (yeah,yeah) that you're trying to cut cross-grain and not long grain. Betting you weren't using your tailstock for support and had some bodacious catches? Only thing I know that will cause what you mention when cutting across the grain. Avoid the catches by swinging the gouge in and through in steps, keeping center gouge above centerline for outside work. You can see the principles here, after the initial center flattening. Yes, I know it's the dreaded
roughing gouge, but when it comes to an edge, a gouge is a gouge.
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=PicturesfromGregs022.flv Watch the swing out, back up, swing out sequence that keeps you from catching under an edge.
You can also pull the gouge, only with a non-bandsawn block, you'll want to start outside and work back in.
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=HollowOne001.flv I'm below centerline here, because I'm about to hollow. At or above with the center of the gouge is safer.
Do you have a chuck? If so, get out your holesaws and set up for a hold right away. Watch the depth of the center drill. You can holesaw and waste away the inside with overlapping Forstner stop bores and grab from inside, or you can use the same with that center bit barely stabilizing and waste away for shoulders for an outside grip.
Glad to have a pin chuck here, though pin jaws would certainly handle what you've got there.
If you're long grain, you'll want to do the same, swing the end, back up. Swing the end, back up. Don't be like this dummy who's using an underhand grip for the sake of photography, and it'll be a lot smoother.
http://s108.photobucket.com/albums/n28/MichaelMouse/?action=view¤t=PeelandPare.flv
